Midpoint
Midpoint
giovannialbe
Midpoint
giovannialbe
Community Visitor
Community Visitor
I'm using Autocad 2025 and I can't find the midpoint command, can anyone help me find it?
maxim_k
Hi @giovannialbe ,
There is no such command in AutoCAD.
Do you mean one of the Object Snap modes?
If yes, then you can specify Midpoint object snap at a prompt for a point, you can do one of the following:
  • Press Shift and right-click to display the Object Snap shortcut menu
  • Right-click and choose an object snap from the Snap Overrides submenu
  • Click an object snap button on the Object Snap toolbar
  • Enter MID at the command prompt
If you mean midpoint between two points (MTP) command modifier, you can find it in the Object Snap shortcut menu or in the Snap Overrides submenu or enter MTP at the command prompt when AutoCAD asks for point input.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Community Legend
Community Legend
@giovannialbe wrote:
...can't find the midpoint command...
Since that is not a command, never has been, you could just look it up in the program's HELP for example, what is it are you trying to do exactly? Perhaps you meant something else that we can help you with.
