Merge two DWG documents
No aplicable
I have a mac, Autocad 2016, and would like to merge two different DWG documents together.
Please advise,
Jerry
0 Me gusta
Responder
Soluciones aceptadas (2)
3.455 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
You can use different methods according to your needs:
- Use clipboard to copy entire drawing and paste it to another drawing - open two drawings, than use menu Edit -> Copy and select all objects in the drawing, than switch to another drawing and use menu Edit -> Paste.
- Use INSERT command (menu Insert -> Block..., than use Browse button to navigate to the drawing you want to insert into opened drawing) - you need to check "Explode block" if you want to insert drawing as individual objects.
- Use menu Insert -> DWG Reference to insert external DWG as reference - a kind of block, which you can see inside current drawing, but you need to edit it separately.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Solución aceptada
Hi @Anonymous,
Maxim_K offers some good suggestions here.
I would also suggest that you check to see if there is anything unique in your blocks before doing this. If one block is in both drawings but is defined differently then you will only end up with one version.
You might also have this problem with Text styles, dimension styles and the like.
Most of this might not matter to you but you might want to be aware of it. To eliminate the problems you can simply rename any of the above.
I usually (if merging big and complicated drawings) like to use external references to make sure that everything looks like it is located correctly and doesn't have any strange things going on. Then, when I am comfortable with it, I will Insert Bind them so they end up in one file.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi jerryjkohn,
I am checking back to see if my post or Maxim_K helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
No aplicable
thanks again!!!!
@john.vellek wrote:
Hi jerryjkohn,
Thanks again!!!
0 Me gusta
No aplicable
thanks again!!!
0 Me gusta
