Anuncios
Measuregeom not working on autocad for Mac 2015
No aplicable
Hi
I've only just started using AutoCAD 2015 for Mac and noticed only the other day that the inquiry distance function has stopped wotking.
Whenever I try to measure a distance, it asks me to enter an option (distance, radius, angle, area etc.), and when I click Distance, it asks me to specify first and then second point again, and then enter an option again, and so on. I really don't know what has happened, any help would be greatly appreciated!
Please help
0 Me gusta
Responder
708 Vistas
1 Respuesta
Respuesta (1)
maxim_k
Welcome to the Autodesk Forums!
From your description it works as it should.
Look at the screenshots:
1/ You call MEASUREGEOM command and select Distance
2/ You pick two points and get the result near crosshairs (if you have Dynamic Input ON) and at the command prompt (you need to expand it with small button with arrow on the right side of the Command window:
3/ If you need to measure multiple distances and get a sum of them, you can use Multiple option after you pick the first point:
4/ Than after you pick the last point and hit Return you will get total distance:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
