Anuncios
Measure Command
Measure Command
No aplicable
When I measure something out on AutoCad 2015 for Mac, the measurements appear with labels on them. For example, instead of just saying 3", the label is d27=3". How can I fix this?
0 Me gusta
Responder
693 Vistas
10 Respuestas
Respuestas (10)
No aplicable
ACAD for Mac forum is here: http://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
0 Me gusta
rkmcswain
That is not a "measurement" per se....
That looks like a parametric dimension.
What command are you launching to get yours?
R.K. McSwain     | CADpanacea | on twitter
0 Me gusta
No aplicable
I'm using the linear command DIMCONSTRAINT (I started learning this program about 2 days ago, so bear with me here).
0 Me gusta
rkmcswain
No problem. I think I used the wrong term myself...
A DIMCONSTRAINT creates sort of a lock on the entity you dimension to maintain the size in the dimension.
Are you trying to place a visible dimension or do you just want to measure something and see the result at the command line?
0 Me gusta
pendean
Community Legend
Community Legend
What are you using as a learning tool? That's not dimensioning alone that you are creating, you are asking the program do do things with it and the object you dimensioned as well.
0 Me gusta
No aplicable
I'm trying to have a measurement show up. I've done the same thing on PCs in the facility and it's worked just fine. I appreciate the help!
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
maxim_k
Hi @Anonymous
I think the case of the troubles you have with dimensioning (measurement as you call it) is ithat you are using wrong button on the Tool Sets palette. I think you are trying to use this one:
From "Drafting" Tool Set, but you need to use this one:
from "Annotation" Tool Set in order to get dimension (measurement) you need.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Great! Again, I really appreciate the help. The next problem is that I don't have that option in my toolbar and I can't seem to find it. How can I turn annotation tools on?
0 Me gusta
maxim_k
You need to use an arrow at the top of the Tool Sets palette to switch Tool sets:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
