Material Textures Showing Partially
Hi Community,
I'm rather new to CAD software, just started not long ago. I've been having trouble getting material surfaces to show, especially with polished surfaces. The surfaces arent showing with dynamic lighting, or are just showing partially, like in the picture i've uploaded. Screen Shot 2016-05-23 at 12.21.50 PM.pngcould anyone guide me on the things that need to be set in order to have material faces show in detail? Thanks
maxim_k
Welcome to Autodesk Forums!
Have you tried to enable Default lighting in the drawing? If you turned it off while inserting new light, you can turn it on if you set system variable DEFAULTLIGHTING=1.
Another way is to add additional light(s) to the scene.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi maxim_k, thanks for the reply. I have tried both things you mentioned, including adding more lights, however I haven't been able to come to a good solution. Haivng Default Lighting ON seems to make it too dark to even get a reflection, and adding additional lights to the scene hasn't done a very good job at making the scene realistic (e.g. only lighting the top faces, side faces remain monotonously dark, and so on.
maxim_k
Can you attach your drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Try to enable Sky and play with its settings - intensity factor - in the Properties palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
