MAC LT 2021 - Project Manager Window Blank
christinaL6559
christinaL6559
I'm trying to organize construction sheets using project manager.  (With the document file open, not in the middle of command)Opening the window the project manager is completely blank- no tools or buttons to load or open. With a previously created DTS file it would not show the sheets. Anyone know what's going on?
0 Me gusta
Responder
Soluciones aceptadas (1)
1.366 Vistas
10 Respuestas
Respuestas (10)
maxim_k
Hi @christinaL6559 ,
What macOS installed on your Mac?
Have you installed latest Update for AutoCAD LT 2021 for Mac?
Have you tried to Reset AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
christinaL6559
Hi!
Version LT 2021 for Mac
Mac OS Big Sur
I wasn’t aware there was an update for AC 2021 for Mac…
I went ahead and installed the hotfix you linked and restarted.
The Project Manager is still showing blank.
0 Me gusta
maxim_k
Solución aceptada
So now you need to try to Reset AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
christinaL6559
Yes this worked. Thanks !
0 Me gusta
No aplicable
Same issue here. I reset and it worked. Thank you!
0 Me gusta
No aplicable
BETTER FIX FOR ME. Read this forum back in June and I've since reset 3 times. Each time after resetting Autocad the project manager started working again, but it stopped seemingly randomly again! It is a pain in the butt to reset autocad as this basically happens every time I open autocad. After 3 frustrating resets (and not wanting to go for 4) I double clicked the top bar on the project manager, as if to 'maximize' the window, and low and behold the project manager magically moved on the screen and suddenly started working! This works every time the project manager is blank. This is my fix for now until autodesk can get it together. Hopefully this works for others too! Good luck.
FYI @christinaL6559
alabrk
Weird indeed. It worked for me too! Thank you for this tip!
0 Me gusta
mark577XS
Community Visitor
Community Visitor
Many thanks for this reply, which is now my go-to solution. I've noticed that it only works if I have one of the files in the Project (.dst) open. Otherwise, it stays blank. I'm currently running AutoCAD LT 2023 for Mac.
0 Me gusta
maxim_k
Hi @mark577XS ,
If no files belonging to the project are open, the manager should appear empty:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
format6
Community Visitor
Community Visitor
This helped me after waiting days for AutoDesk support to respond. 3 Years later and this bug still exists, how embarrassing given what we pay for this software every year. If anyone else is over 3rd rate software I suggest checking out BricsCAD. I am going to move over to it after my current project completes.
0 Me gusta
