Mac 2018 version- Hiding an XREF Layer
No aplicable
Hi All,
Me and my colleague keep walking into the issue were we have many CAD drawings/XREFS with one main XREF of our architect linked in it.  We are new to AutoCAD Lite on Mac but know this was no problem in the Windows version of CAD 2015. When we hide a layer in our architects' main XREF our other drawings don't ask for us to reload the updated XREF drawing as we were used to. Also, the hidden layer doesn't appear to be hidden in there with or without reloading. It seems as if we can no longer hide layers in our XREFS.
Is this a known bug? Is this something that just isn't supported anymore since after AutoCAD lite 2015? It's really a bummer for us as we have to update many many (about hundred) of drawings by hand instead of just clicking "Hide" in our main-XREF.
Hope somebody is able to help. Any help is appreciated.
Best Regards,
Thomas Lazarom
0 Me gusta
Responder
847 Vistas
8 Respuestas
Respuestas (8)
maxim_k
Welcome to Autodesk Forums!
Hi Thomas,
You need to set VSIRETAIN system variable to 1 in the to which the main drawing is attached. Then the changes in layer states will be reflected in it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
 @maxim_k might have guessed your issue correctly. Try setting visretain to 1/0 which controls layer property overides and post back with your results. If it is not the solution to your issue, please prepare a Screencast to show this behavior. You might also attach a couple of sample files that show this action.
John Vellek
0 Me gusta
maxim_k
Hi Thomas,
That was my fault VISRETAIN system variable to 0 (zero) in order to be able to see the changes in layer states in xref.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
cage_free
Community Visitor
Community Visitor
This does not work for my AutoCAD LT 2023.
0 Me gusta
maxim_k
Hi @cage_free
Have you tried to set VISRETAIN=0 and reload Xref?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
cage_free
Community Visitor
Community Visitor
Choosing 0 does not work either. What ended up working is for me was LAYFRZ > Settings > Block Selection > Block
0 Me gusta
quinn.zhang
Hi Thomas
If you want to get xref's layers on/off settings synchronized in your current drawing, you need this command 'VISRETAINMODE' , and change the value from 0 to 1( or from 0 to 2047).
But you can't see this command before version 2019. As a recommendation, please update your AutoCAD for Mac to the latest version like AutoCAD 2023  and it can help solve your problem.
See these two pages for more details.
https://help.autodesk.com/view/ACDMAC/2023/ENU/?guid=GUID-32CFDDB7-E6F8-4BEF-9538-65862F87092D
https://help.autodesk.com/view/ACDMAC/2018/ENU/?caas=caas/sfdcarticles/sfdcarticles/Modified-xref-la...
Quinn Zhang
AutoCAD for Mac team.
0 Me gusta
quinn.zhang
Hi @cage_free Please try this command ' 'VISRETAINMODE' , and change the value from 0 to 2047, then reload the xref. It works fine on AutoCAD LT for Mac 2023. btw, the visretain value is 1 and visretainmode value is 2047 on my side.
0 Me gusta
