Anuncios
Looks like we get an update - Finally!
maxim_k
maxim_k
Hello all,
Glad to inform you that Update 3 for AutoCAD 2015 for Mac was released today:
The Update 3 resolves the compatibility issues on OS X El Capitan. The Update 3 is a combo update which also includes the fixes in previous updates. It can be patched directly over the previous versions of AutoCAD 2015 for Mac. It is recommended that you read the entire document properly before you apply the update to your product. For reference, please save this document to your hard drive or print a copy.
Security
  • Includes a security patch to address a vulnerability where a specially crafted raster image in a drawing can trigger unauthorized code execution.
El Capitan
  • On 10.11, Crashes when edit text.
  • On 10.11, Crashes when use Layer palette.
  • On 10.11, Crashes when open some drawings.
  • On 10.11, Crashes when work in Layout.
  • On 10.11, Crashes when close drawing from Full Screen mode. Disable the full screen and restore back to maximize window mode.
  • On 10.11, Visor flashes in some cases.
  • On 10.11, Some sub-dialogs shows at back of the parent dialog.
  • On 10.11, Open file dialog navigates to the AcOCUI.framework folder by default.
  • On 10.11, Appload dialog does not remember last folder.
AutoCAD2015Update3_English
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Responder
2.114 Vistas
10 Respuestas
Respuestas (10)
Kevin_Megel
It's a good new's now I can upgrade to El Capitan, and un need take Autocad 2015 !
Kevin Megel
Ce post vous a été utile ? N'hésitez pas à aimer ce post.
Ce post a-t-il répondu à votre question ? Cliquez sur le bouton Accepter la solution.
Je suis un simple utilisateur, je ne travaille pas pour Autodesk
0 Me gusta
maxim_k
The Update is only for AutoCAD 2015 (see link above)
and for AutoCAD LT 2015:
http://download.autodesk.com/SWDLDDLM/Updates/ACDMAC/2015/AutoCADLT2015Update5_English.dmg
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Kevin_Megel
I know, I think I take Autocad 2015 now !
Kevin Megel
0 Me gusta
No aplicable
Is this compatible with Apples 10.11.1 update that was released later today ?
0 Me gusta
maxim_k
Yes, of course.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Good news - presumably we will get a fix for ACAD LT shortly? or does Update 5 for LT MAC do that?
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Yes, it does.
You can upgrade OS after you apply Update 5 for AutoCAD LT 2015 for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
This is good news for 2015 users, but unfortunatly I'm still on 2013.
You wouldn't know by any chance if there will be a patch for this version?
I'm currently running Beta Mandalore and I guess it will only be time that this will be discontiued as a testing platform.
Thanks in advance if you have any news.
Regards
Nigel
0 Me gusta
maxim_k
Hi Nigel,
Sorry, but I'm not aware about the plans on Update for 2013 version, it was updated for Yosemite, but now - who knows?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Hi Maxim,
Hmmmmm......
Pity really.
If I'm now forced to acquire a newer version of LT, then this might be time to consider other software options.
I need to move to BIM at some point and since Revit is not an option for Mac, AutoCAD LT was at the time (2 years ago) a temporary solution for financial cost effective reasons. Full fat AutoCAD is not an option and certainly not for nearly £4k and so, my research shall now continue .......... ArchiCAD or Vectorworks.......
Thank you LT, it was good while it lasted :cara_con_una_leve_sonrisa:
Hasta la Vista
0 Me gusta
