Anuncios
Loft tool has "Cross sections only" option locked on.
a00829556
Observer
a00829556
Observer
Observer
I am trying to use two CLOSED, parallel and level splines to make a lofted volume. I have tried to turn off the "Cross sections only" option, changed the lofting settings, closing the splines (they are confirmed to be closed), and reselecting the volume mode; it repeatedly makes a surface as can be seen in the last image.
I tried to use the loft tool on a previous set of splines successfully used to make a solid and it still does not work. How can I make a solid with Loft??
Resulting loft surface with cross sections onlyResulting loft surface with cross sections only
0 Me gusta
Responder
340 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Hi @a00829556 ,
Please verify that LOFT command has Solid mode enabled at the beginning of the command.
Plus - the splines geometry can case LOFT command to create surface instead of 3D Solid.
Can you share your drawing or part of it here? I'll look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
a00829556
Observer
Observer
Yes, I have selected solid loft multiple times and it refuses to change from "Cross sections only".  The whole drawing is enclosed, thank you :cara_con_una_leve_sonrisa:
0 Me gusta
maxim_k
Hi @a00829556 ,
I have no problem creating a 3D solid with the LOFT command (sections only) in your drawing:
See attached drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
alina.balkanskaia
@a00829556 Hello, nice to see you in Autodesk Community! Was the @maxim_k answer helpful for you? If yes, please, mark his answer as the solution. Otherwise, please, post more information here!
Alina Balkanskaia
0 Me gusta
