Linetype scale issues
having not used Autocad for a while ( autocad 2012) I know have Autocad LT for MAC.
I seem to have forgotten how to get linetypes ie dashed and batting to look the right size in Model & Paperspace.
If its right in Model space It looks ridiculous in Paperspace & Vice versa.
I know there are now 4 different scales , can someone give me a clue?
I have attached an example
maxim_k
Hi Garry,
Everything is correct with linetypes in the drawing you attached. You just need to use REGENALL after you switch to Layout to see dashed lines correctly.
In Model space use REGEN command when dashes are nit showing correctly.
Plus, you can use VIEWRES command to increase "zoom percentage" to maximum value - 20000 - as it also affects the appearance of linetypes in the drawing:
Command: VIEWRES
Do you want fast zooms? [Yes/No] <Y>:
Enter circle zoom percent (1-20000) <100>: 20000
Regenerating layout.
Command: *Cancel*
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Many thanks, I will try this tonight when I'm back on it, will post again later.
Gerry
Sent from my iPhone
Emmsleys
Hello, @Anonymous
Welcome to the Autodesk community.
Following up on your thread, were you able to test the above suggestions? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
