Anuncios
Line weight in crosshatch too thin.
No aplicable
I am importing a 2010 AutoCAD file into illustrator. I have my line weights defined ByLayer in AutoCAD, and have the crosshatch on a specific line weight. when I import into illustrator all the line weights are what they should be except the crosshatch, which is very tiny. The boundary of the crosshatch is the correct weight but the actual hatching is not...I have attached a screen shot of what the hatching looks like.
Any help adjusting the line weight of the crosshatch?
0 Me gusta
Responder
Soluciones aceptadas (1)
1.239 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Which lineweight you assigned to the layer where you put the hatch in AutoCAD?
Have you checked lineweight of hatch lines in Illustrator?
Are they the same? I mean in AutoCAD and in AI?
You also can check the color of the hatch lines if it is not black, they may seem thinner than what they really are.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
I have the hatch on the same layer (default line weight) as the gray lines on the top and bottom if it, but it would appear that the hatch line weight is even smaller than the default also.
It seems that the hatched section seems to import into illustrator as some sort of object. It doesn't tell me a line weight for that, even if I expand and try to select the lines themselves. The default line weight in illustrator is .709pt
It would seem that the change needs to be made in autocad prior to illustrator?
0 Me gusta
maxim_k
Solución aceptada
Explode hatches in AutoCAD before importing DWG in Illustrator.
For some reason when AI imports native AutoCAD hatches, their lineweights changes to 0.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
