Anuncios
Line Types Changing on Wrong Layers
No aplicable
Hi there,
Thank you in advance for any help any of you can provide me with.
I am trying to dive into line types and thicknesses using layers but when I change my line type on a layer I want to be a certain line type, it will change to another line and I cant seem to figure out how to get the layers to respond properly. It is probably very simple.
Thanks again!
0 Me gusta
Responder
354 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Welcome to Autodesk Forums!
Hi Daniel,
If you are unable to see the changes you make to linetype of the layer, than you need to play with Global Scale Factor in Lintype Manager window (Menu Format -> Lynetype...):
Try to make it smaller.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Hi @ Daniel.j.,
Were you able to find a solution or a workaround? It's been a few days since you posted in this thread.
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
0 Me gusta
