LINE AND MEASURE COMMAND FAULTY
maryada_k
Observer
maryada_k
Observer
Observer
HI, I USE THE STUDENT LICENSE FOR AUTOCAD FOR MAC, AND ABDRUPLTLY ONE DAY MY LINE COMMAND STARTED BEHAVING WEIRD EVERY TIME I ENTER A COMMAND FOR EXAMPLE- 5'<0 IT ENDS UP ATTACHING MY LINE TO XY AXIS, ALSO MY MEASUREMENT COMMAND GETS STUCK IN A LOOP WHERE IT ASKS ME TO TYPE IN THE TYPE OF MEASUREMENT THEN CHOOSE START POINT AND END POINT AND ENDS UP AGAIN ASKING FOR TYPE OF MEASUREMENT. I HAVE BEEN STUCK WITH THIS PROBLEM FOR A WHILE NOW, PLEASE HELP.
0 Me gusta
Responder
321 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Hi @maryada_k ,
Not sure that I understand correctly about the result you get. Can you illustrate this behaviour somehow? Maybe with screenshots.
If you mean MEASUREGEOM command, then it is a standard behaviour. To exit from this command you need to hit Esc key.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maryada_k
Observer
Observer
Screen Shot 2024-05-20 at 1.23.21 PM.pngScreen Shot 2024-05-20 at 1.23.36 PM.png
As you can see in the photos above- this is after I gave a specific line dimension and angle, second point of my line always goes and attaches itself to YX axis point no matter what I do. This also happens if I try to move an object in a specific direction to a specific point.
As for the measure command it asks me to enter an option and when i type d for distance ( although I already chose meausure distance command itself) it again asks me to select first and second point then again to enter an option until I exit the command with no measurement.
0 Me gusta
maxim_k
Hi @maryada_k ,
1/ To enable relative coordinates for direct input use menu Tools -> Drafting Settings, then select Dynamic input tab and pick on "Settings" button under "Pointer input" :
Activate "Relative coordinates" option active in "Format" section:
 Save settings with OK button.
2/ After you complete distance measurement, you can exit MEASUREGEOM command with Esc key or by selecting "eXit" option:
Command:
MEASUREGEOM
Move cursor or [Distance/Radius/Angle/ARea/Volume/Quick/Mode/eXit] <eXit>: d
Specify first point:
Specify second point or [Multiple points]:
Distance = 100.0000,  Angle in XY Plane = 0,  Angle from XY Plane = 0
Delta X = 100.0000,  Delta Y = 0.0000,   Delta Z = 0.0000
Enter an option [Distance/Radius/Angle/ARea/Volume/Quick/Mode/eXit] <Distance>: X
Command:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maryada_k
Observer
Observer
No I am doing all of this, just cross checked all the settings you mentioned it is still not working, you think my account could have a bug or something?
0 Me gusta
maxim_k
@maryada_k
Sorry, I didn't notice that you have Dynamic Input disabled
With Dynamic Input disabled you need to type:
@5'<0
and hit Return after you pick the first point of line.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
