Layout not loading in project
No aplicable
Hi All,
I'm having an issue with importing existing layouts into a new project.  I have several drawing files with associated layouts that I'm importing into a new project (ie. site plan, foundation, first floor, second floor...etc) The issue arises when I try to import the foundation layout.  When I try to add it, it doesn't load into the project browser, instead it loads the site plan layout.  They are different drawing files so I'm confused as to why it won't recognize the foundation layout as a separate asset.  When I delete the site plan layout from the project, and try to load the foundation layout, again it will just load the site plan layout.  I'm able to load all the other layouts properly.  Has anyone come across this issue before?  Thank for your help.
-Will
0 Me gusta
Responder
Soluciones aceptadas (1)
405 Vistas
1 Respuesta
Respuesta (1)
No aplicable
Solución aceptada
Update:
So I couldn't leave it alone.... I re-saved the foundation drawing under a different name and bingo.  Tried it again and it loaded fine.  I suspect it had something to do with the file name.  It was saved as "Foundation/Basement".  Saved it as just "Foundation" and it worked.  Probably had something to do with the file path "/" in the name.
