Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Layers not publishing in AutoCAD for Mac
ilporte
ilporte
Hi - I'm having this same problem: missing xref layers when I use BATCHPLOT but showing up fine when I use PRINT. The missing layers are unfrozen and set to plot in all files involved.
Is there a way ensure BATCHPLOT is using "print as displayed" as the plot style?
Thanks.
@ilporte - Moderation team has edited title for findability.
pendean
Community Legend
Community Legend
@ilporte is your background publishing setting still turned on? Turn it off as a test right now then try BATCHPLOT again, see if your missing content issue goes away.
ilporte
@pendeanI'm sorry I don't know how to access that setting! I'm on AutoCAD for Mac - should have included that in the context.
What does the background publishing setting do?
pendean
Community Legend
Community Legend
@ilporte You are in the wrong forum for your product variant: AutoCAD for Mac's dedicated forum is over here
https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/autocad-mac-forum-en
I'll see if I can get an admin to move your posts there in the meantime.
maxim_k
Hi @ilporte ,
Please specify your autoCAD for Mac version and macOS installed on your Mac.
Where are the Xref files located? Are they on the local disk or on a network drive?
You may also verify this:
PDF files created via Batch Publish don't show External references (Xref) in AutoCAD for Mac
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ilporte
Thanks @maxim_k - I'll definitely try the solutions at that link. I'm using autoCAD 2025 version V.100.M.416 and macOS Sequoia 15.4.1.
ilporte
-EXPORTTOAUTOCAD command generated a new file that worked fine with batch publishing. Thank you!
