Anuncios
Issues with dimensions tool settings
No aplicable
Hi
I have recently set up my dimensions tool settings and all was working fine and then the text became unreadably small. on inspection the settings look unchanged but i cannot seem to get the text size to go back to what i had which when working fine..
i have lost my arrows as well so something is a miss
cheers steve
0 Me gusta
Responder
Soluciones aceptadas (2)
1.802 Vistas
26 Respuestas
Respuestas (26)
No aplicable
yes this is what i have tried to do but there was no change so i went in to the individual txt and changed it.
i have looked at the settings again and they are no different from yours but the Dims are still not coming up like they should..
0 Me gusta
maxim_k
So do you want to say you still have issues with dimensions in the file I edited?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
No the file you returned to me works fine and my dimensions tools work fine when im in your file, but when i go back to my file i have the same problem which is baffling as they are both essentially using the same tool..
ive looked at the settings when in your file and they are the same as mine ..
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
@Anonymous-k simply removed your text overrides that he noted in the image he posted: do you know how to do that? It has nothing to do with dimstyle settings.
maxim_k
Solución aceptada
I corrected only DIMSCALE on the Fit tab (under the picture with dim style illustration)
Plus some of the existing dimensions in your drawing has dimension style overrides, which prevent these dimensions to show correctly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Hi guys..
ok no i dont know how to do that but im keen to learn..
many thanks
0 Me gusta
No aplicable
ok great i think i have sussed it now.
it was this as you pointed out..
im still not sure why it changed mid work flow but ill keep an eye on it.
thanks again
0 Me gusta
