Issues with choosing certain options
No aplicable
Hi, new to the forum and auto cad in general, I have been working my way through YouTube tutorials with some success. What I have found though is I don’t have the same options as is available in some of the videos, not sure if it’s because I am using Mac and the video user is Windows.
My issue is when I go to make a circle, the user in video has the option to go to command line and click on diameter, I don’t have the ability to do this, diameter is in the command line but when I pass over it I can’t select it. I also have this issue with other commands?
Any help would be greatly appreciate, thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
414 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi Craig,
@Anonymous
In AutoCAD for Mac you cannot select command options by clicking them on the command line.
Instead you can:
- select options from right-click context menu:
 - select options from Dynamic input (if it is enabled) after pressing Page Down key on the keyboard:
Use the capital letter of the option word on the keyboard:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thanks that’s helped massively!
Do you also know how to save drawing unit? They reset every time I start up, is there any way to save this? Thanks again!
0 Me gusta
maxim_k
Hi Craig,
What do you mean by "drawing unit"?
Do you need specific unit settings for new drawing? If yes, you can create new drawing set up units in it, save it as template (DWT) and use this custom template each time you create new drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
If I go into units, it has drawing units at the top, so basically just the units drop down?
So could I ‘save drawing as’, then rename it and use this going forward with the units saved? Many thanks!
0 Me gusta
maxim_k
You need to choose save as "Drawing template":
Units and all settings in the drawing will be saved with the Template.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
