issues exporting to stl
mauricio.zuleta.l
Observer
mauricio.zuleta.l
Observer
Observer
hi, I'm new as AutoCAD user, our team is trying to design an artificial medical ventilator and we try to do it with AutoCAD, the model attached is part of the pressure system, but when we try to export it to .stl the object cannot be selected and of course cannot be saved as stl, appreciate your help
0 Me gusta
Responder
Soluciones aceptadas (1)
1.322 Vistas
5 Respuestas
Respuestas (5)
pendean
Community Legend
Community Legend
Solución aceptada
Did you look it up in HELP, or notice the commandline feedback? STL exporting from AutoCAD requires your objects to only be Select solids or watertight meshes, your file and objects are not either one of those things. AKA they are not true 3D objects, just a bunch of lines, plines and flat surfaces.
You need to build an actual 3D model from SOLIDs first before you export to STL. Back to the drawing table my friend.
mauricio.zuleta.l
Observer
Observer
Thanks, I’ve been trying all as said in the tutorials and help, and still don’t get how to do it, I’ll keep trying
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
maxim_k
Mauricio,
Actually it is not very difficult in your case.
You already have profile in your drawing, all you need is to create closed polyline from it, then use REVOLVE command to create revolved 3D Solid.
I've done this in a few minutes. The resulting STL is in the attachment.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mauricio.zuleta.l
Observer
Observer
thank you very much, Ill keep practicing and improving, just started so really appreciate it
best
0 Me gusta
