install an Acad.pat file in Mac
I have been using Acad since 1986. I have been using PC based Acad and Acad LT on the Windows platform for years. I have an ACAD.PAT file that I have been updating over the years and would install it into each new upgrade. Never a problem.
Well, I updated to ACAD LT 2016 for Mac. I am new to the Mac platfrom so I have no idea how to install the file now.
Does anyone know how to get the file location? I did in Windows, but am at a total loss on this Mac.
Lou
pendean
Community Legend
Community Legend
Google Search offered a half dozen answers including this one http://www.simplecad.com/installing-autocad-hatch-patterns-mac.htm
You missed this notice in this forum before posting your question http://forums.autodesk.com/t5/autocad-lt-general-discussion/the-autocad-lt-for-mac-forum-has-moved/t...
thanks Dean,
I found that same page after a google search. I just cant seem to find how to find the file structure.
I will repost in the forum for Mac.
Thanks again
Lou
john.vellek
Hi @Anonymous,
This is actually pretty easy to do on a one by one basis.
Open the Hatch Library on your screen in AutoCAD for Mac.
Drop down the list to show Custom
Towards the bottom of the list is "Add Patterns"
Select this and it allows you to add the hatch pattern.
If you want to get into the Hatch location on your Mac, the default location is /Users/<username>/Library/Application Support/Autodesk/AutoCAD 2016/R20.1/roaming/@en@/support/Hatch Patterns.
Normally this location is hidden. So, in FINDER select HOME from the GO menu. Next, from the VIEW menu select SHOW VIEW OPTIONS. near the bottom selet SHOW LIBRARY FOLDER
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
maxim_k
Welcome to the Autodesk Forums!
It is not difficult:
Call HATCH command, then:
....you are in place you are looking for.
Note. To see the animation in my reply better - right click on it and select "open in new tab (window)".
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
The instructions how to find acad.pat are here:
http://forums.autodesk.com/t5/autocad-for-mac-general/installing-acad-pat-for-mac/td-p/6365251
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
thanks John,
That worked.
Much appriciate the fast replies from everyone.
Lou
