Inserting a template
No aplicable
I have been able to insert by using the insert command.  I saw a vidio about inserting a layout by clicking on status bar and opening the show drawings and lay out.  I then right click in an open area I get a dropdown that says new layout from template and I click on that.  Opens up templates and if I click on a pre drawn auto cad template file and open it, it shows up in the insert lay out box, click ok and it works.  When I try the same thing with my own created dwt file it does not show up in the insert lay out box.  I am thinking it is the way I set up my file.
Greg
0 Me gusta
Responder
Soluciones aceptadas (2)
1.787 Vistas
8 Respuestas
Respuestas (8)
maxim_k
Hi Greg,
Just tested this on my side and I'm able to insert Layout from existing drawing file.
Could you attach your template here? I can try to figure out the case.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
If I understood you correctly, you cannot use INSERT command to deal with a DWT file.
0 Me gusta
dr.palmer
Hey Dean,
What does it take to get a reponse removed from a discussion?
0 Me gusta
dr.palmer
disregard previous post
thanks
0 Me gusta
No aplicable
Maxim,
I can not figure out how to send you my dwt file of the same thing. I tried inserting it as an dwt, dwg, block, wblock with no luck.
No problem using auto cads title blocks.
Greg
0 Me gusta
maxim_k
Solución aceptada
Compress it and attach as ZIP archive.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Maxim,
Sorry, I can’t figure how to send you a dwt file. Talked to apple and they con’t help me. I will keep trying, most of the time I seem to get it.
Thanks again,
Greg
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
See if these how-tos help you figure it out:
osxdaily.com/2012/01/10/how-to-zip-files-in-mac-os-x/
http://macs.about.com/od/faq1/f/How-To-Zip-And-Unzip-Files-And-Folders-On-A-Mac.htm
0 Me gusta
