AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Insert Field from A Table Cell
1 REPLY 1
blakemarchi
1191 Views, 1 Reply
I am looking to insert a field of text into my drawing that references a table within the drawing itself. I have tried to use the object>formula>cell as a field entry but when I try to select the right cell within the table I get a invalid field code error when I select choose on the field menu. Any ideas on how to reference table data throughout the drawing by using fields?
1 REPLY 1
maxim_k
in reply to: blakemarchi
Hi Blake,
I'm afraid, it is impossible. AutoCAD fields functionality doesn't allow to get table cell contents other then numbers. You use Formula type for field, but formulas works only with numbers...
Look at these topics:
https://forums.autodesk.com/t5/autocad-forum/table-cell-text-into-field/td-p/2416053
https://forums.autodesk.com/t5/civil-3d-forum/copying-table-cell-text-into-a-field/td-p/3144502
NOTE: AutoField for AutoCAD by CADIG will not work in AutoCAD for Mac
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
