Hi all!
I'm having problem when using autocad 2015. My ex-version is 2007, and when i draw, i can input command anytime and anywhere in drawing field. But when i upgrade on 2015, its not available anymore because i have to move cursor in to command line pallete to text commands. that is so inconvenience. Hope you all can help me!
Thanks a lot!
Hi and Welcome to AutoDesk Forum,
>> i can input command anytime and anywhere in drawing field. <<
still autocad and all versions have the same behavior.when you finish your commands or press Esc button to finish any operation;command line will be ready to take any new CAD command.since you work with old CAD version(2007) it will be useful to have a look INPUTSEARCHOPTIONS command to see the new features presented while working with autocad (see attached image)
Good Luck...
Thank for reply sir. what i mean is that have to move the cursor right onto the command line dialogue box( the black box in the image i post here) to text command. this doesn't like 2007 version which i can input commands no matter where the cursor is.
try to press keyboard Esc button then just start any command without mouse movement and tell us what happened?
With DYNPROMPT and DYNMODE set to 1 the command line moves next to the cursor. Does this change the behavior?
@Anonymous wrote:Thank for reply sir. what i mean is that have to move the cursor right onto the command line dialogue box( the black box in the image i post here) to text command. this doesn't like 2007 version which i can input commands no matter where the cursor is.
Thanks "pendean" for your reply, and i'm so sorry for forget to tell you all that i'm using cad on Mac. It is so confusing because everything so different to Window. And back to your solution, that command line box can not anchored anywhere on drawing field( on mac ofcourse). I think that we are getting the right way and i have to find out how to dock it on( cause at the moment, the command box seem like not a part of drawing field, it is floating).
Thanks Maxim_k. my Mac is El capitan 15 inch. i already did that behaviour but there is nothing happen . My problem is, i think, that the command window can't be turned to be a part of drawing window! it just like a plugin window( that weird thinking happen in my mind now)
Thank Maxim, " AutoCAD doesn't "feel" keyboard input when mouse is out of the Command window", this is exactly what i mean( i'm from Vietnam, then my english is so bad 🙂 ) . So you mean this is a Autocad feature in Mac, and we can't change it, do you? so dissapointed if this is true, it is so complicate when you have to move the cursor, your eyes, and hand everytime you need a new command! Thanks for your help!
