Incompatible File System
maxim_k
Welcome to Autodesk Forums!
Hi NARELLY,
Can you describe your problem in more details?
What AutoCAD version you are trying to install? (if you are really trying to install AutoCAD and do not do anything else)
I don't see information about macOS version on the Disk Info window you attached, so it appears you are trying to install AutoCAD on non-system disk (partition). If so, you cannot install AutoCAD on it. AutoCAD can be installed only on System partition, where macOS is installed.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
