AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
If I upgrade my computer to Monterrey, will the AutoCAD LT 2022 work?
2 REPLIES 2
nicogomesprod
257 Views, 2 Replies
I have a license for an autoCAD LT. for Mac , installed and working fine .
But to install it  last April , I had to go back on my MAC system from Monterrey to Big Sur , for installation did not happen with Monterrey installed .
My question now is , can I upgrade my computer back to Monterrey ?
will the AutoCAd LT  2022 work ?   or will I have to update autoCAD ?
is there an update of it for use with Monterrey ?
Shall I stay with Big Sur ?
I'm a person that like having my computer and system always up to date
@nicogomesprod
The topic title has been edited to improve findability by @alina.balkanskaia. Original: AutoCAD Lt 2022 Monterrey
2 REPLIES 2
maxim_k
in reply to: nicogomesprod
Hi @nicogomesprod ,
At first you need to check that your AutoCAD LT 2022 is updated with the latest 2022.3 Update.
With this Update installed your AutoCAD LT will run even under macOS 13 Ventura.
After  you install this update, you can safely update to macOS Monterrey.
The update is available in your Autodesk account page or you can use menu "AutoCAD LT" -> "Check for Updates" to check for Updates.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
nicogomesprod
in reply to: maxim_k
Hi Maxim
thank you very much , for your help .
I need someone expert to assure me .....will update do version 2022.3  first
Thank you
best
