i was working in a project and this error shutdown autocad
when I try to open the recovered file, autocad says it doesn't exist and I have to start the work from 0
maxim_k
Welcome to Autodesk Forums!
Hi Jesus Daniel,
Can you find your drawing manually in Finder? It (or previously saved version of it) should be inside SEGUNDO PROJECTO folder on your Desktop.
You can also try to find autosave copy inside "/Users/jd/Documents/Autodesk/Autosave" folder and the name of the drawing should have the form: TDT_1_XXXXXXXX_XXXXXX.bak
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
i can’t open the “recovery” file
maxim_k
Have you tried to use RECOVER command with "recovered" file?
Can you share here your broken "recovered" file? Or you can send it to my e-mail: mkanaev@yandex.ru
I'll look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Hi Jesus,
I received your drawing, but looks like the file was seriously damaged during emergency save.
Sorry, but it is impossible to recover it.
If you can find autosave copy or backup version, you can try to get the results of your work from them.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
The autosave does not work either simply that document ceased to exist, although it does not matter anymore and make my scheme again
