I lose automatic field areas when opening file
10:49 PM
Hi, and thanks in advance for your support.
I have a problem using AutoCAD for Mac: when I open an AutoCAD drawing created on Windows, I lose all the fields of areas which were created with the command "field". I mean: I see the correct measure and text, but it is no longer related to the corresponding polyline.
Is there, maybe, some variable I must set for this not to happen?
Link copied
