I can't find the "Manage Libraries icon" or another way to get to "Manage Libraries".
robin_mckercher
Observer Observer
robin_mckercher
Observer
Observer
I'm using AutoCAD 2025 for Mac. I am following a text book ... where this icon is supposed to be is different.
maxim_k
Hi @robin_mckercher ,
Since 2022 version, the blocks palette has been changed.
In order to add block library to the list of the block libraries on the Blocks Palette you need to use this button (#2 on the screenshot) to display a file navigation dialog box, where you can specify a folder, a drawing file, or one of its block definitions to insert into the current drawing as a block:
Then you can browse Block Libraries as described >>>>HERE<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
rosie_lucas1
Hello @robin_mckercher
Just checking in—did the response shared by @maxim_k help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
