Switched from Window to Mac OS 10.11 and when I try to print Arch C (24x18) format, the software thinks I am using an 18 in roll vs a 24 leading to a lot of wasted paper since I have to cut 6 in every time I use it.
I tried all available configurations and I think AutoCad LT 2017 doesn't speak properly to the printer because all was fine with Window Xp.
Anybody got leads on this?
Thanks.
Solved by maxim_k. Go to Solution.
Solved by pendean. Go to Solution.
I agree it is an orientation problem. However, I con not choose 18x24 vs 24x18. My choices are Arch C, Arch D, etc.
When I select preview, the image shown is fine and the drawing seems to be oriented the right way with no paper waste, ie, it shows printing with the wide edge of the drawing aligned with the width of the roll, 24".
Then something fights all the settings and rotate the drawing on its narrow edge and waste a band of paper 6x24 that I have to cut manually. There is an auto-rotate function once in the preview, but it does not affect the result.
Not being computer savvy, I am at lost on how to program the printer or make both systems (AutoCad and the printer) agree on what I am asking.
Any suggestion you have in mind with baby step explanation?
Could be. I tried saving on PDF and then print from that file and the same issues showes up. I also tried to batch publish in PDF and most of the notes on the drawing (leader notes ant MText notes) will print on top of the existing notes in a different format. Looks like Mac doesn't like AutoCad PDF converter either.
Good Idea, so I did change the orientation on the drawing on the AutoCad page itself (I put it on its short side) but to no avail.
I went through the whole plotter menue to find the autorotate function, no joy either. I'll look into more discussions on the web. We'll see how it goes.
Thanks Maxim, Batch printing is now up and running as advertised.
J-Yves
Speaking of system variables, is there one I should know about for the rotation of the print?
Dean, I think I know now what you meant. Instead of working on the screen, I went to the page set up manager and created the custom page as you said. Looks funny on the screen, but it seems to have fixed the problem for now....
Thank you all for your help. I actually killed two birds on this one.
Cheers!!
Jean-Yves
On HP Designjet T2300, I see the setup for the paper rotation, and i assume you can find it too. It is in the print dialog, select "Finishing" in the dropdown. So you don't have to create all custom paper sizes.
Wei
It is not wise to print from a PDF in the engineering world. Straight from AutoCAD to a plotter always yields the most efficient print. I'm guessing OP is operating under this assumption.
