I am attempting to TRIM parts of a block that intersects with two parallel lines. However, whenever I select the two lines and use the TRIM command, all it says is "Cannot TRIM this object". Can blocks not be trimmed at all? I can't seem to find any other commands that will do the job.
Thanks!
Solved by maxim_k. Go to Solution.
