Anuncios
How to set paper size
No aplicable
I need to set my plot paper size to 18"x24"
also all of the scales are in 1:1 format. If I type in .75:1 is the equivelent to 3/4" = 1'-0"
please help
0 Me gusta
Responder
450 Vistas
7 Respuestas
Respuestas (7)
maxim_k
Welcome to Autodesk Forums!
If you don't have paper size in the default list of paper sizes, you need to create custom paper size :
http://autodesk.blogs.com/between_the_lines/2011/01/quick-tutorial-plotting-custom-paper-sizes-in-au...
And use it when you print or create Page Setup.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
it only gives me the options for cm. is there a way to set everything to be in inches?
0 Me gusta
maxim_k
Where you have cm? If when you create custom paper size, than you need to verify current units in Mac OS System Preferences.
In AutoCAD you need set units for the drawing with UNITS command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
I've done all that. Still when I try to set the print paper size it's in cm. and when I do the inch conversion. And measure the page. It measures over 11ft
S
0 Me gusta
maxim_k
If you will try to create custom paper size in application other than AutoCAD - do you have paper size in cm?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Yes.
S
0 Me gusta
maxim_k
So if you already set units to Imperial in OS X System Preferences (International pane) than looks like it is printer software issue.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
