Welcome to the Autodesk Forums!
Yes, there is a problem with installing AutoCAD LT 2013 for Mac on Yosemite and I know that Autodesk working on this problem. The same problem is with full AutoCAD 2013 for Mac.
Actually you can install it even now, but if you are not sure about your "IT knowledge" I cannot recommend you do this, because there is another issue with SP3 for AutoCAD LT 2013 for Mac which also is not resolved for now - after SP3 for AutoCAD LT 2013 installation you will not be able to start AutoCAD without another trick.
Anyway, here are the links to my posts on how to install AutoCAD 2013 for Mac with SP3 on Yosemite:
A/ How to install from original media - AutoCAD_LT_2013_English_Mac_OSX_R1.dmg - and apply SP2 and SP3:
At first I need to say that you should be very careful using this method in order not to break Yosemite on your Mac.
So here are the steps:
1. Locate SystemVersion.plist file inside /System/Library/CoreServices/ folder on your Mac, backup this file somewhere in safe place, than copy it to your Desktop and open with TextEdit.app. You will see this:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>ProductBuildVersion</key>
<string>14A389</string>
<key>ProductCopyright</key>
<string>1983-2014 Apple Inc.</string>
<key>ProductName</key>
<string>Mac OS X</string>
<key>ProductUserVisibleVersion</key>
<string>10.10</string>
<key>ProductVersion</key>
</dict>
</plist>
2. Using TextEdit.app edit substitute two instances of <string>10.10</string> with <string>10.9.5</string>
The contents of the SystemVersion.plist should look like this:
<dict>
</dict>
</plist>
3. Save SystemVersion.plist file, quit TextEdit.app. Than copy edited SystemVersion.plist file from your Desktop back to /System/Library/CoreServices/ folder and chose "Replace", than enter your Admin password to confirm replacement.
4. Now start AutoCAD 2013 installation from the AutoCAD_LT_2013_English_Mac_OSX_R1.dmg installation image. The installation process should go fine now. After installation apply SP2 for AutoCAD LT 2013 (which you can download here:http://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-lt... ) without starting AutoCAD.
5. Now put original SystemVersion.plist file which you backed up in step #1 back to /System/Library/CoreServices/ folder and chose "Replace", than enter your Admin password to confirm replacement.
6. Restart your Mac. You will see AutoCAD LT 2013 icon in the Dock.
7. Apply SP3 for AutoCAD LT 2013 for Mac, but don't launch it after installation.
B/ How to start AutoCAD LT 2013 after you apply SP3:
- download trial version of AutoCAD LT 2015 for Mac
- install it to your Mac
- run it once (maybe this step is optional, not really sure) and close (quit AutoCAD LT 2015)
- try to launch AutoCAD LT 2013, now it should start.
- remove AutoCAD LT 2015 trial version from your Mac (or you can leave it - as you want).
Maxim
