AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How to automatic insert circles
3 REPLIES 3
336 Views, 3 Replies
I am very new to AutoCAD, we are using in in class, as well as I am trying to make something for my self.  Now my problem, I have created a drawing of a jig, consisting of 4 plates/elevations length and width is around 600mm X 400mm, with only differences in outer shape dimensions, where each elevation has lines that are 25mm apart in both X and Y direction, which means that they cross each other every 25mm. I would like a 7mm circle to be automatically drawn at each cross point. Otherwise I will have to draw 414 circles, in 4 drawings/elevations.
Is this possible?
Regards
Gremling
3 REPLIES 3
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous
Have you tried FILLET command?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Hi, I could not get it to work with fillet commands, all I ended up with was bent lines.
Below is an attached image of a part in the project. I want the circles to appear in every place where the white lines cross each other, circles to be preferably 7 to 8mm, The same is the case for the other elevations/levels.
Regards
Trond Martin
aka Gremling
maxim_k
Ah, I see. You need to try another command - ARRAY.
In your case you need to select Rectangular option to create rectangular ARRAY with row and column spaces you need.
http://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-E23F6125-E5E9-4645-9615-23717902C33B
http://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-07CB282A-2C71-46FE-937F-BC3DFB2C068B
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-02084B7E-4C8E-430E-983A-C8802B8AF04A
See attached drawing
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
