AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How do I get a Poly Line To Fill?
3 REPLIES 3
764 Views, 3 Replies
How do I get the red poly line to fill? It seems to not want to be an object.
3 REPLIES 3
Emmsleys
Would you be able to provide a sample file?
Have you notice that this happens with all your drawing files?
Sarah Emmsley
Technical Support Specialist
ara_neresesian
hi
when you are in a 3d view the polyline cannot be display as you want,
but if you need a poly line with width , you have to draw a solid with same width, or draw a closed polygon with inside hatch
Emmsleys
Following up on your thread, were you able to find a solution? Or a workaround? Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technology Administrators
