How do I change the print boundary in paper space? [MAC]
I am having an issue printing my A3 sheet created in paper space. There is a dashed line which surrounding the sheet which cuts off some of the viewport. How do I widen this so I can take advantage of the whole sheet of paper? (See Screenshots)
Screen Shot 2018-11-15 at 21.39.55.pngScreen Shot 2018-11-15 at 21.40.21.png
john.vellek has embedded your image(s) for clarity
cadffm
Thats your printable area..
You choose a papersize..
the papersize-definition is length x width and non-printable border left/right/up/down
Think about: Not every printer can print up to the outer paper border!
If you want to edit the printable border you have to re-define your papersize definition,
or if you using a standard papersize format, create your own custom papersize (with another name).
Or simply: Choose the well fit papersize, big enough for your wanted viewport, frame and titleblock.
Sebastian
ennujozlagam
hello, check your paper size and scale of your drawing. thanks
Hi @Anonymous
In the plot manager box,select your printer & the right side of your printer name there is a properties click that button.
where you can modify your top,bottom,left & right printable area of your sheet. I attached the image for your reference.
I think this will solve your issue.
Great day.
john.vellek
Hi @carl.harris.97,
Since you are doing this in AutoCAD for Mac, this will be slightly different than in Windows.
I find the easiest was to do this is to create a Custom paper size and set the margins to 0 mm or 0 in.
I made a quick video that shows this process. I open the Plot window and assign a printer (AutoCAD PDF) and then create a Custom A3 paper size no margins. This is called Full Bleed.
John Vellek
john.vellek
HI @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
