Help with making an arc in AutoCAD.
postYRNZJ
Observer Observer
postYRNZJ
Observer
Observer
Hi everyone!
So I just started an online course in AutoCad and have been given this task. I am having a bit of trouble figuring out how to do this. Maybe some of you could help telling me what to do here?
The task:
Describe how to draw an arc with a center point of 120.60, a radius of 15.75 mm and an arc angle of 150 degrees. The starting angle is 90 degrees. Draw the arc. How is the arc positioned if the starting angle is 0 degrees? Also draw this arc. Indicate on the drawings what the starting angle is.
Greatly appreciate all replies!
maxim_k
Hi @postYRNZJ
Command line input should be:
Command: ARC
Specify start point of arc or [Center]: C
Specify center point of arc: 120,60
Specify start point of arc: 15.75 <- turn ORTHO mode on, move mouse vertically from the center point and type 15.75
Specify end point of arc (hold Ctrl to switch direction) or [Angle/chord Length]: A
Specify included angle (hold Ctrl to switch direction): 150
For the second task - the same, but in the step #3 (after turning ORTHO on) - move mouse to the left from the center point of arc.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
postYRNZJ
Observer
Observer
Thank you so much for your answer! It helped me a lot!
