Anuncios
Help!!! Viewports to print to scale
No aplicable
 Hello all!
I am a student fairly new to AutoCad and cannot seam to figure out the viewpoints. I need to print each row on a single piece of paper at 1:50, how do I do this??
Thanks in advance for any help you can give me!
0 Me gusta
Responder
Soluciones aceptadas (1)
958 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
At first you need to set UCSFOLLOW system variable to 0 (zero) in Model space:
Command:
Command: UCSFOLLOW
Enter new value for UCSFOLLOW <1>: 0 <- type 0 and hit Return here
Then create layout and set in it paper size you need.
Now create viewport, activate it by double clicking inside viewport and roughly zoom to the area you want to see in the viewport.
Then use Status Bar to set scale of the viewport to 1:50, use pan to adjust view inside viewport. Activate paper space by double clicking outside viewport.
Look at layout with name "Layout with 1_50 viewport" in attached drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thank you so much, thats exactly what I need!
And thank you for braking it down for me, I can see now - seams so simple!
0 Me gusta
