Download AutoCAD Hatch Patterns
After downloading:
1. Unzip the files
2. Add the .pat files to either acadiso.pat OR acad.pat.
3. Create palette of hatch patterns
Hi! I've been trying to add hatch patterns to my Support File Search Path folder (image 1 below) but the file names are grayed out. Can anyone assist me with this? I've also tried directly to Add Patterns in the Hatch Library (image 2 below). The file names show up but when I add them it says "Error in Pattern File" and nothing shows up in the Library. Help please!
Obviously I really need help! Don't know how to delete...
I tried that as well. They loaded into my library but it says Error in Pattern File.
Here's the folder I downloaded. I also tried what you recommend with the folder and it still didn't work. I thought it might just be this file but I downloaded some patterns from other websites and the same thing happened. I appreciate your patience and assistance in helping me with this...
Those patterns are not suitable for AutoCAD, they appear to be intended for some Corel application.
You should seek alternatives.
I'm pretty sure these are not Corel Draw files. The website says they're AutoCAD files:
After downloading:
1. Unzip the files
Rather than editing ACAD.PAT just
1. place all of the pattern files in a separate directory.
2. add that directory to the ACAD source file path
3. look for the patterns under the hatching panel's CUSTOM tab
hth,
Hugh
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestions that @pendean @hugha and @maxim_k provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
SO , Why does Autodesk make installing hatch patterns on AC LT mac so difficult?
No, I didn't ever get it to work.
I agree!
Hi @Anonymous,
I'm sorry to hear you're having a tough time adding custom hatch patterns to AutoCAD LT for Mac.
It looks like there were some issues with the hatch pattern files you were originally trying to use. Were you able to find .pat files that are compatible with AutoCAD? If so, you should be able to follow the steps in this AKN article to add the hatch patters into AutoCAD.
Please let me know if this works.
If this post answers your question or solves your issue, please click Accept as Solution so others in the community can find it easily.
