HELP - Dynamic Input not working
TaylorC2E9A
Observer Observer
Message 1 of 16
TaylorC2E9A
Observer
Observer
Need help! My dynamic input all of a sudden stopped working. I used to be able to use shortcuts for everything, no matter where my curser was. I could define rectangles using dimensions (x,y). I could prompt a command questions no matter where my curser was. NOW, I have to do EVERYTHING in the command line - no matter what my dynmode is set to (1,2,3). Can't possibly have to resort to command line 😞
Also, prompts like MIRROR would always pop up "delete original? Y/N" and now nothing prompts, and I have to hover over the command line. This is no way to live! Please help!
Replies (15)
Message 2 of 16
user181
Hi @TaylorC2E9A  Try using the command DSETTINGS and go to the Dynamic Input tab and make sure all the items or all the options you want are checked
Message 3 of 16
TaylorC2E9A
Observer
Observer
No that actually makes it worst 😞 I can do some commands when I UNCHECK "Enable Pointer Input". The screen looks like the spazzes out if I have all checked... If that makes sense. A letter quickly pops up and then disappears.
Message 4 of 16
TaylorC2E9A
Observer
Observer
So in DYNMODE <2> I can at least type a command in the field and it prompts ON the command line. It used to show the command options right next to the curser.
And in DYNMODE <2> I can define a rectangle by (x TAB y) no longer by just a comma.
Message 5 of 16
WeTanks
Reset Settings to Default
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 6 of 16
TaylorC2E9A
Observer
Observer
Tried that too! No luck.
Message 7 of 16
pendean
Community Legend
Community Legend
@TaylorC2E9A Curious how a an actual program reset did not work for you: did you reset, then reinstall your custom backups (aka reintroduced the problem)? or something else?
Please post a screenshot of your ABOUT command pop-up and confirm your OS please.
Message 8 of 16
TaylorC2E9A
Observer
Observer
See photos.
And see the reset option I used. I ONLY uploaded a .ctb file for plotting. Nothing else.
Message 9 of 16
cadffm
This is not AutoCAD LT, this is AutoCAD LT FOR MAC, another animal of software on another OS wither other problems&solutions as the Win version.
There is a "AutoCAD for MAC" forum next door and we read about similar issue there.
Sebastian
Message 10 of 16
maxim_k
Hi @TaylorC2E9A ,
The only one thing you need to do is to install latest Update to AutoCAD LT 2021 for Mac :
https://help.autodesk.com/view/ACDLTM/2021/ENU/?guid=AUTOCADLT_MAC_2021_3_FIXED_ISSUES
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 16
alex34C6P
Community Visitor
Community Visitor
I am having this issue and I have the latest CAD update installed.
Message 12 of 16
alex34C6P
Community Visitor
Community Visitor
I did a program reset, turned my computer off and on, and made sure that Dynmode was set to 3. If I have it set to 2 it works, and if I have it set to 1 it works, but if I set it to 3 it stops working.
Message 13 of 16
maxim_k
Hi @alex34C6P ,
What AutoCAD for Mac version do you use?
What macOS version is installed on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 16
alex34C6P
Community Visitor
Community Visitor
I am running macOS Ventura Version 13.21
This screenshot shows the version of CAD I'm using.
I see you reference a 2021.3 Update but when I check for updates I'm told
that my product is up to date. See second screenshot
[image: Screenshot 2023-06-06 at 9.36.01 PM.png]
[image: Screenshot 2023-06-06 at 9.38.27 PM.png]
Alex
Message 15 of 16
maxim_k
Hi Alex,
>>>>>> I see you reference a 2021.3 Update but when I check for updates I'm told that my product is up to date. See second screenshot
In order to be able to see an alert about Update, you need to enable Notifications for AutoCAD as Banners or as alerts in macOS System Preferences.
Or you can download Update from your Autodesk account:
https://manage.autodesk.com/
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 16
alex34C6P
Community Visitor
Community Visitor
That worked, thank you for your help!
I'm still confused though because I do have alerts set up for AutoCAD on my
computer, these are the settings I had in the screenshot below. Also,
AutoCAD on my computer told me that I was current on all updates even
though clearly I wasn't. I think this might be another bug.
[image: Screenshot 2023-06-07 at 10.04.05 AM.png]
