Hi, I'm about killing myself for this problem...
I'm using Autocad 2018 on MAC Mojave, everything was going fine until I installed Adobe Acrobat X and updated my printer's firmware (espon xp900). I uninstalled Acrobat but it doesn't help and I don't think it's a printer problem...
When I "insert a PDF underlay", it's shown with a transparente background, that's great I can see every line clearly, but when I print a layout with this attached PDF (plot: dwg to pdf), the preview shows correctly but prints always with a black background, just as shown in my model space. My only solution for this moment is to save my plotted PDF file as jpg, then print it.
john.vellek has embedded your image(s) for clarity
I tried to trun off the "adjust colors for background" option, my pdf shows with it's original white background in my model space, but prints still black.
Does anybody know how to fix this??
Solved by maxim_k. Go to Solution.
From Adobe Acrobat, open the Pdf then go to File>Export>Image>jpeg (your version of Acrobat may vary, the key is to turn the Pdf into a jpeg/tif/png.). Back in your dwg, attach the jpeg instead of the Pdf. You can turn the 'white' areas of the jpeg transparent by selecting the jpeg then modifying 'transparency' in the Properties Palette. You will need to tell Cad what color you wish to be transparent using your mouse. In properties palette, click transparency>select jpeg>click an area of white. When you click on a white area of the jpeg, Cad considers it to be a sample swatch of the color you want transparent. Check 'plot transparency' in the plot dialog window to get the right effect when you go to plot.
Hi, yes I contacted my Epson technique support, finally they told Le to try to update my adobe PDF software. I installed the lateste version and now it’s resoved: to print correctly I have to open the autoCAD generated PDF with adobe acrobat but not with « Preview » .
Conclusion: that’s not an AutoCAD issu at all 🙂
