I want to hatch this 3D object with a solid fill so as the inside of the red lines is filled with solid red and the inside of the blue lines is filled with solid blue
Solved by maxim_k. Go to Solution.
Have you tried to switch to one of the 3D Visual styles?
Maxim
I created 3d Solid in your drawing with the same parameters as yours and colored its faces.
Following up on your thread, were you able to find a solution?
Did any of the posts in the thread help with you issue?
Please post back in the thread if you are still having an issue with AutoCAD LT or Select Accept as Solution for the post’s that helped.
Thanks for your time.
I do appreciate the ideas listed above, but unfortunately none of them have solved my problem. I did attach my .dwg files as David requested. If anyone has any other ideas, I would be most appreciative.
Thank you!
