With LT 2017 for mac, has something changed with the GROUP command? In previous versions you could just select what you wanted to group and it would just do it. Now it wants to name it etc and still doesn't end up grouping the elements.
Neil
Solved by Emmsleys. Go to Solution.
Solved by maxim_k. Go to Solution.
Following up, did any of the posts in the thread help with you issue?
Post back in the thread if you are still having an issue with AutoCAD I'm sure the community will be more than happy to help.
