Anuncios
Ghost lines appear in extruded geometry
No aplicable
After drawing lines/arcs, joining and then extruding, phantom lines appear in the geometry in Model space.
They shift/disappear/reappear sporadically as I pan and zoom. Seems to only effect shallow extrusions (1/4" lauan material).
Any way to fix this?
0 Me gusta
Responder
1.313 Vistas
5 Respuestas
Respuestas (5)
maxim_k
I cannot reproduce this issue on my side with any Visual Style. Can you attach your drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
I have the same problem except it is in paper space.  Phantom lines will appear on objects, usually connecting with something like a hole in the solid object.  If I zoom in close they go away.  But when I print the layout the lines print as well.  I have attached a page where this appears.  It is in an isometric view of a round flat lid.  Any help would be appreicated.
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Could you attach DWG file with his issue?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Here is the cad from which that layout came from...you can see lots of examples of the issure in here.  Thanks
0 Me gusta
maxim_k
I can reproduce the issue on my side.
After quick investigation I can say that this issue could be a bug in AutoCAD (in both versions - for Mac and for PC): these lines appears in viewport with visual style other than 2D Wireframe when 3D Solids are extremely thin in compare to its area.
Look here:
http://forums.autodesk.com/t5/autocad-2007-2008-2009/quot-ghost-quot-lines-on-thin-3d-solids/td-p/19...
You can try to use SOLPROF workaround or create flatten view of 3D objects with FLATSHOT command, than put the result to Layout.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
