from Illustrator to Autocad (spline)
No aplicable
Hi all,
I know that there's a way to export a project from Adobe Illustrator to Autocad (polyline), but I need to convert it in spline.
Could someone kindly tell me how to do?
Thanks in advice,
have a nice day
0 Me gusta
Responder
Soluciones aceptadas (1)
4.182 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Welcome to Autodesk Forums!
If you mean straight segments, than it seems impossible to force Illustrator to export them as splines (curved paths always exports to DWG as splines).
But I can not understand why you want straight segments to be splines in AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
We are a graphic studio, which design custom signs. To design our works, we use Adobe Illustrator.
When we realize projects engraved in iron, we turn to a company that has a special machine for cutting of this support. they have explicitly asked us to send them the .dwg project, but in spline instead polyline.
We don't use Autocad, but if I understand it, the problem is that cutting in polyline is more structured and requires long times, while in spline is more simplified and rapid.
This makes sense? :cara_con_una_leve_sonrisa:
thanks in advice,
best regards.
0 Me gusta
maxim_k
Solución aceptada
Polyline is less structured than spline - I'm sure.
If you have only curved paths in custom signs, than they will be exported to DWG format as splines.
I know only one application, which exports to DWG all kind of paths (curved and straight) as splines - it is CorelDRAW.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
There used to be an add-on for Illustrator called DWG Export that did a better job of creating what you seek: but they haven't had an update is a long time.
Look into getting AUtoCAD to fix your Plines into Splines there: download a trial versionand test for yourself for free for 30-days.
0 Me gusta
