08:18 AM
It's been awhile since I've used AutoCad tables and I'm having difficulties formatting the column alignment. I would like to:
- center to the header cells in Row 2,
- but I want to left justify all the rows below the header.
Autodesk helps indicates that I should right click on the column headers to set the alignment. I do not get an option to do so when I right click on the column headers.
- Also, how do I change the alignment for different rows within a column? When I double click and select the text within a cell, the alignment options are greyed out and I cannot select them.
Thank you. File is attached. I'm working on the table in the Finish Tab.
