Anuncios
Font issue - ACAD LT 2024 for Mac
RangrStudio
RangrStudio
When plotting a drawing (to pdf) the font changes to italic. The same drawing on the same computer works in Autocad LT 2023.
In LT 2024, the font displays correctly on screen, but the pdf output changes the font to an italic verision.
The font is Avenir.
Again, the same drawing plots correctly from the same machine using Acad 2023 or Acad 2022.
Please help.
Responder
Soluciones aceptadas (1)
7.044 Vistas
66 Respuestas
Respuestas (66)
RangrStudio
The hotfix fixed the font issue.
0 Me gusta
HawkAIA
Wow, that was fast!  That appears to have resolved the issue for me.  Thanks!!
0 Me gusta
lauramstein
Community Visitor
Community Visitor
I am having the same problem with Century Gothic. I have used this font for years on all previous versions of AutoCad LT for Mac without issue. I just updated to 2024 and now I'm getting a bold italic font on my PDFs. The font displays correctly in the DWG but not the PDF. Please let me know if you can solve this!
Thanks!!
0 Me gusta
maxim_k
Hi @lauramstein ,
Have you installed >>>>THIS<<<< Hotfix?
The 2024.0.1 hotfix fixes some critical issues and improves security. It is recommended for all users.
Fixed Issues
Shortcut
Sometimes AutoCAD crashes when hit shortcut keys.
ESC key is mapped to wrong functions in some cases.
Shortcut has problems on Azerty keyboard.
Publish
In some cases the invalid publish path cannot be corrected and publish cannot be continued.
Text
Text edge shows blurred when zoom in.
Some font style changes in plotted PDF.
Other
On macOS Ventura, the last item in a dropdown menu cannot show up.
"Use Shift key to add to selection" setting cannot be saved after AutoCAD LT quit.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
lauramstein
Community Visitor
Community Visitor
That did the trick! Thank you!
0 Me gusta
maxvasher
I am having the same issue with Century Gothic. In paper space the font shows correctly but when I save as pdf or print the fonts applied to paper space print in bold italics. Fonts within model space print correctly but fonts applied to paper space do not.
0 Me gusta
maxvasher
0 Me gusta
maxim_k
Hi @maxvasher ,
If you are using AutoCAD 2024 - have you seen >>>>THIS<<<< post?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
sglynne
I also have this issue with Arial font.
0 Me gusta
maxim_k
Hi @sglynne ,
Fixed Issues
Shortcut
Publish
Text
Other
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxvasher
Solución aceptada
I reloaded the program from my subscription on the autodesk website and the problem went away.
0 Me gusta
sglynne
Thank you, @maxim_k  and @maxvasher , I will try these.  Before your replies I reverted back to AutoCad Lt. 2021 but will try 2024 with your advice.
0 Me gusta
shahrobm
I had the same issue.  I removed and reinstalled version 2024, but the problem wasn't resolved.  I reverted to 2023 version until this apparent bug is fixed.
0 Me gusta
HawkAIA
Make sure you have the latest update (see attached for how to check).  Updating resolved the problem for me.
0 Me gusta
shahrobm
Thank you very much, things look fine now!
A new version must've been posted as I reinstalled ACAD LT 2004 for Mac on Saturday and still had an issue.
0 Me gusta
maxim_k
Hi @shahrobm ,
Reinstalling AutoCAD LT for Mac won't help, as the original installer you downloaded from your Autodesk account page doesn't include 2024.0.1 Hotfix, which you need to install separately.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
katie9GAXR
Observer
Observer
How do you install the Hotfix? When I click Check For Updates, nothing happens at all.
0 Me gusta
pendean
Community Legend
Community Legend
You can always grab updates from your Accounts Page here
https://manage.autodesk.com/products/ACDLT?version=2024&platform=WIN64&language=EINT
0 Me gusta
HawkAIA
Log on to your autodesk account using a web browser.  A quick way to navigate there is to click on your account name in the far upper right hand corner of your autocad screen and pull down "manage license".  That will take you to the page in Maxim's screenshot. The click on the download button next to the hot fix.  If the download does not automatically startup, find it in your downloads folder and double click on it to run the installer.  Hope this helps
0 Me gusta
maxim_k
Hi @katie9GAXR
@katie9GAXR wrote:
...... When I click Check For Updates, nothing happens at all.
In order to be able to see notifications about Updates you need to enable them for AutoCAD in macOS System settings.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
