Anuncios
flatshot There are no solids or surfaces that can be projected.
No aplicable
Hello.
I can not do flashot in the 3D model (see attach) Commands: CONVTOSURFACE, CONVTOSOLID etc - not worked. Command MESHSMOOTH - it works incorrectly, breaks some elements of the model. What could be the solution?
AutoCad for Mac 2016 MacOS 10.11.5
regards
A
0 Me gusta
Responder
Soluciones aceptadas (1)
17.458 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
Hi A,
After you convert polyface meshes to Mesh objects with MESHSMOOTH command you need to set Smoothness level of the resulting Meshes to "None" via Properties palette.
Look at the attached DWG, where I converted all pface meshes to Meshes with smoothness = None.
You can also find FLATSHOT result in the attached drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
I tried to explode the objects to many lines and then I did the flatshot and it works for me
0 Me gusta
