Anuncios
File Became Read Only after Mojave Update
eduardedy
eduardedy
Maybe someone has an idea about the following:
After Mojave OS update, any drawing which was made before the update became ''Read Only''.
I'm using AutoCAD 2018 and installed the last AutoCAD update.
0 Me gusta
Responder
Soluciones aceptadas (2)
2.297 Vistas
13 Respuestas
Respuestas (13)
pendean
Community Legend
Community Legend
is the problem just the one file, or only files in that folder, or ALL files everywhere and not this deep down?
0 Me gusta
maxim_k
Solución aceptada
Hi Eduard Adrian,
Try not to use column view in finder or in "Open DWG" window, use list or icon view instead.
Does this help?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Solución aceptada
And look here:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
eduardedy
I'm using a NAS device to store all the files and yes, all the files have the same problem, apart from if the file is on the Desktop.
0 Me gusta
eduardedy
Thank you. It's working now!
Best!
0 Me gusta
No aplicable
This solved it for me. I hope they come out with an update soon. Strange that column view will cause that!
0 Me gusta
mmany
I'm using a NAS, this solution doesn't  work. It works if I move the files to my desktop, but I can't open files on the NAS no matter what view I'm using in Finder.
0 Me gusta
mmany
My reply was meant to be to Maxxim's post with the solution.
0 Me gusta
mmany
0 Me gusta
maxim_k
Hi Michael,
No problems with opening drawings from NAS (Seagate Personal Cloud) in AutoCAD 2018 on my side. Even with Column view in Finder and in AutoCAD.
Have you logged to NAS as registered user?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mmany
Interesting. I'm using a Synology DS19+ and after the update to Mojave, can no longer open any DWG files stored on it (or better to say they're read-only). I'm logged in and it's working fine. I'm not having any trouble at all opening DWG files on my Macbook's hard drive in any view-mode in Finder.
0 Me gusta
maxim_k
So it could be some issue related to Synology DS19+ and AutoCAD for Mac.
Are you able to open documents for editing from your NAS in other applications?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mmany
I'm able to open and edit all other file types. DWGs only are opening read-only, and only since the update to Mojave....
0 Me gusta
