Anuncios
Exporting plot to PDF
No aplicable
When I export a plot to a PDF, I am having an issue where lines are missing, words and letters are misplaced, etc. i want to know how I can get the exact image/plot I am seeing inside AutoCAD to export fully to a pdf
0 Me gusta
Responder
319 Vistas
1 Respuesta
Respuesta (1)
maxim_k
Welcome to Autodesk Forums!
Please specify your AutoCAD version.
If it is AutoCAD 2016 for Mac:
>>>> lines are missing
Possible cases:
- the lines are on non printable layer. Solutions: make layer printable via Layers palette or move lines to the printable layer
- the lines have zero lineweight and you are viewing PDF file in Preview application. Solutions: use Adobe Acrobat Reader application to view PDF files or change lineweight of the lines to something greater than zero.
Possible cases:
- you are using specific True Type font (or Open Type Font) for the Text Style. Solutions: try to set system variable USEQUARTZFONT=0:
http://help.autodesk.com/view/ACDMAC/2016/ENU/?guid=GUID-673F3876-0F2F-49CE-86D6-46F90013B23D
or try to use different TTF (OTF) font for the Text Style.
>>>> etc.
Can you be more specific?
You can also attach your problem drawing along with PDF output for further investigation.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
