Existing dimensions alignment
No aplicable
Good afternoon. Is there a command to align multiple existing dimensions referring to a single dimension? Now I do these by selecting the "grips" but I don't know if this is the right way to do it.
Many thanks and best regards to all.
Francesco.
0 Me gusta
Responder
Soluciones aceptadas (1)
482 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi Francesco,
I believe DIMSPACE command will help you:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2016/E...
When you will be prompted for the value option - you can use a spacing value of 0 (zero) to align the dimension lines of selected linear and angular dimensions end to end.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thank you very much Maxim. This command solved my issue.
0 Me gusta
