the 3kb files are defect (incorrect, not repairable content).
The file "4545kidhaven.dwg" opened well on my system.
Renaming the file "4545kidhaven.bak" to "4545kidhaven_bak.dwg" worked also well.
What happened in both cases is that referenced files are missed (2 JPG-files, one PDF-file).
_AUDIT found no issues.
So they should open well on your system too.
Can you please start AutoCAD and then command _ABOUT and show us a screenshot from that dialog?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
